Author Topic: anyone ever fixed 17705 ????  (Read 2897 times)
Offline snap-on
« on: 17 March 2010, 20:37 »
got the 17705 come up again , pain in the arse ! cant find leak , done tb clean and reset , have a newish 007 , have kn panel , changed the valve in intake hose -n75? clear code and all is fine for days/weeks then like this morning slight hesitant in revs on bypass , like boost then lack of . scanned and have the dredded 17705 . clear code and it goes a lot better till next time .
Has anyone actually found a fault that is common or that actualy fixed this fault ?
Offline corf
Re: anyone ever fixed 17705 ????
« Reply #1 on: 17 March 2010, 20:39 »
have same problem, doing my nut in
Offline Rhyso
« Reply #2 on: 17 March 2010, 20:44 »
there is no common fault sadly
Found out tonight that Dai-Cymru's old Golf was down to a faulty MAF.
New on has been fitted, code has disappeared and not much can keep up with it  :laugh: :laugh:
Start reading this
http://uk-mkivs.net/forums/p/170257/1115840.aspx#1115840
Offline Mk1Macca
« Reply #3 on: 17 March 2010, 20:48 »
mine seems to have reappeared, but I haven't actually noticed anything wrong with the car?
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 17 March 2010, 21:02 »
DV is generally the cause if it's still the standard one, but if it's not an obvious boost leak then it's usually a split pcv/vac line or dodgy throttle body.
Offline Stronz
  • Sold!
« Reply #5 on: 17 March 2010, 21:32 »
I sympathise with Snap-on and  Mk1Macca...exactly the same position here. Have looked for leaks, replaced things, cleaned things and cant get rid of the code  :angry:
And as already said, the appears to be nothing wrong with the car (in fact, on the motorway today, I got a nice 45.2mpg - not seen those figures in a while!). It's just annoying me the code is there (no light on dashboard though)
Offline topher
  • Administrator
  • fully functioning
« Reply #6 on: 17 March 2010, 21:35 »
Another odd one i remember was a dodgy map sensor which was chucking out odd readings but only when on idle.. hold at 2k rpms and the fault stayed gone!
Offline snap-on
« Reply #7 on: 17 March 2010, 23:00 »
i dont get light on dash either as with most people . i get around 27mpg but i do have a dodgy theromstat ! mine runs fine just this morning seemed wierd so scanned and found the code again .
will have a good look soon as my new cambelt kit , waterpump and fanbelt turned up from the dealer at a nice cheap £119 all in , and i will be putting the car on the ramp sat to renew all those parts and have a good look around for a boost leak/split pipe at same time ! oh and change thermo too !
like im really looking forward to doing all that on a saturday !!!
Offline rsblue
« Reply #8 on: 17 March 2010, 23:22 »
Start reading this
Dai told me he changed this so it was the last thing i replaced  when we took it out originally to clean it  - we took it from the maf casing  took the sensor out and found it had no resistor and to be honest could not see any way it had been fixed there as the mounting contacts were very clean , so put new bosch maf in and its like a new car. The MAF does not show a fault with no resistor either !!!
Offline Rhyso
« Reply #9 on: 18 March 2010, 08:04 »
Start reading this
Ah didn't realise you'd become a member! Welcome along  :smiley:
