Author Topic: 17521 - Oxygen (Lambda) Sensor  (Read 1391 times)
Offline Cacwn Tew
  • God I'm getting old........
« on: 17 March 2010, 16:56 »
Dear All
I have had a look on the forum for the above fault without much results.
Are we looking at a sensor which one, or is the actual cat itself on its way out?
Could it be as simple as a poor connection as I have had a SS exhaust fitted last month.
1 Fault Found:
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
 P1113 - 35-10 - - - Intermittent
thanks! :smiley:
« Last Edit: 17 March 2010, 17:03 by Cacwn Tew »
GTi to Transporters to GTi
Offline snap-on
Re: 17521 - Oxygen (Lambda) Sensor
« Reply #1 on: 17 March 2010, 20:22 »
Sounds like front 02 sensor fault (one before cat) . can you see it switching on live data on scanner ? should be showing mv going up and down like a yo yo .
Offline Cacwn Tew
« Reply #2 on: 17 March 2010, 20:27 »
Lost me now, not that hot on the vag, can scan and clear thats about it.
thanks
Offline snap-on
« Reply #3 on: 17 March 2010, 20:31 »
does vag com not show live data of sensors etc working ? or is it just a code reader
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 17 March 2010, 20:39 »
01 engine - Measuring blocks
o2 related channels are 030 - 049
