Author Topic: hubcentric spacers  (Read 9240 times)
Offline bobreece
hubcentric spacers
« on: 17 March 2010, 15:38 »
i think am going to need some spacers 10mm should be fine but where to get the cheapest from and of good quality can anyone help as i am new to all this spacers thing.
found these but was hoping for cheaper http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150423695586&ssPageName=STRK:MEWAX:IT
Offline Purely VAG
Re: hubcentric spacers
« Reply #1 on: 17 March 2010, 19:31 »
Yep there em, Youll won't get a set cheaper than £45 as the FK/Eibach ect.. sets are expensive.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline bobreece
« Reply #2 on: 17 March 2010, 19:45 »
but are the cheap ebay ones ok or will they possiable break or cause problems?
also i just thought will i lose the use of the sercurity bolts i alreeady have?
Offline Purely VAG
« Reply #3 on: 17 March 2010, 19:49 »
They're fine, they're cheaper because there made of steel, Expensive ones are make of light/strong grades of ally.
Ideally best getting a lighter set so you aren't increasing your unsprung weight alot but if your not bothered go for it.
And as long as your locking nuts still reach to turn 2 threads or so thats fine, You have 4 other bolts torqued up.
Offline bobreece
« Reply #4 on: 18 March 2010, 03:45 »
can i buy longer sercurity bolts? this is all doing my head in now wish it was simple
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #5 on: 18 March 2010, 12:34 »
yes you can buy longer locking bolts if your alloys are oem not aftermarket or reps then grayston do a 60mm length set pt number LB163 i have a set of these and cut two front and two rears down to the size required for me running spacers  :wink:
2000 Mkiv GTi 1.8T AGU
Offline bobreece
« Reply #6 on: 18 March 2010, 16:15 »
you got a website link m8?
also how big a spacer can i use with them?
« Last Edit: 18 March 2010, 16:18 by bobreece »
Offline Purely VAG
« Reply #7 on: 18 March 2010, 16:53 »
Standard length is 28mm, if they're 60mm,theres 32mm of spacing, More than enough, Cut to length
Offline bobreece
« Reply #8 on: 18 March 2010, 16:55 »
cheers m8 what type bolt head do i need as there is about four to choose from
Offline Purely VAG
« Reply #9 on: 18 March 2010, 16:57 »
Tapered for Steelies, Radius for most alloys.
