Author Topic: Soggy Footwell  (Read 2162 times)
Offline T_J_G
Soggy Footwell
« on: 17 March 2010, 14:54 »
Yo!
My car developed a leak and has a soggy drivers side footwell. This Saturday I intend on taking the carpet out of the car and using a Vax to clean it thoroughly. Should I do anything else while it's off? Anti bacterial stuff maybe?!
Tim
Offline Dan J
Re: Soggy Footwell
« Reply #1 on: 17 March 2010, 18:54 »
yep get some zoflora antibac from asda,tesco etc etc, make up a weak/medium strength mixture in a spray bottle and mist over the carpet and allow to soak(after you've removed the manky water its been sitting in)
check for leaks around your door/windscreen rubbers, check your rubbers on bulkhead aswell.
Offline T_J_G
Re: Soggy Footwell
« Reply #2 on: 17 March 2010, 20:15 »
I've found the leak :) I'll pick up some Zoflora from work.
Thanks!
Offline Dan J
Re: Soggy Footwell
« Reply #3 on: 17 March 2010, 21:08 »
where was it dude?
Offline T_J_G
Re: Soggy Footwell
« Reply #4 on: 17 March 2010, 21:23 »
Bonnet release grommit from where I put boost gauge in.
Offline Dan J
Re: Soggy Footwell
« Reply #5 on: 17 March 2010, 21:42 »
glad you found it chap :grin: take it you've sealed it up good and proper now :wink:
Offline T_J_G
Re: Soggy Footwell
« Reply #6 on: 17 March 2010, 22:37 »
Put a new grommit in but will be buying some sealant and going mad when I strip it out
Offline T_J_G
Re: Soggy Footwell
« Reply #7 on: 21 March 2010, 16:48 »
Cheers for your help Dan all sorted and smelling better :afro: Zoflora FTW!
Offline Dan J
Re: Soggy Footwell
« Reply #8 on: 21 March 2010, 17:35 »
no probs dude pleasure :wink: glad you've got it sorted,
 zoflora is really economical, 1 small capfull diluted in 500ml of water in a spray bottle works wonders(good for spraying on your kitchen work surfaces to keep them free of bacteria, i always use it in my spray extraction machine to eliminate bacteria building up during the drying process when i do car interiors.
