Author Topic: cheapest place for 312mm discs  (Read 2086 times)
Offline bobreece
« on: 16 March 2010, 21:08 »
where is the cheapest place to get good 312mm disks from? found some on ebay but unsure and eurocarparts are out of stock
« Last Edit: 16 March 2010, 21:11 by Rhyso »
Offline Purely VAG
Re: cheapest place for 312mm discs
« Reply #1 on: 16 March 2010, 21:13 »
The cheap ones on ebay were fine, i had a set, don't know how long they last though, i didn't use them long
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline bobreece
« Reply #2 on: 16 March 2010, 21:27 »
well its 69 for pagid ones from euro carparts or or 69-79 for ebay ones but have drilled holes and grooves which ones to go for ? do the drilled bits help or cause more problem i have read alot on ukmkivs but still unsure
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #4 on: 16 March 2010, 21:49 »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline bobreece
« Reply #5 on: 16 March 2010, 21:55 »
cheers nice find. is it better to go with plain disks then?
Offline bobreece
« Reply #6 on: 16 March 2010, 22:00 »
it all comes down to do i get grooved drilled or plain?
Offline richw911
« Reply #7 on: 16 March 2010, 22:57 »
plain  :wink:
Read the 312mm upgrade thread - tells you why  :wink:
Offline bobbarley
  • I'm kind of a big deal...
« Reply #8 on: 16 March 2010, 23:21 »
i would recommend these (very first item) :)  >>>  http://buypartsby.co.uk/ebc-brake-discs-final.php?year=2000&Submit=Next&make=Audi&model=S3&sub=&eng=1.8000
They're the EXACT ones I've bought.  Don't forget you need 2  :wink:
Offline nadlad
  • Building Surveyor MRICS
« Reply #9 on: 17 March 2010, 02:13 »
tps accordign tot hsi thread 77 quid two fornt discs 312 and 4 front pads
ill believe it when i order em though
http://www.golfgtiforum.co.uk/index.php?topic=146225.msg1340238#msg1340238
<<<Big Build Thread>>>
