Author Topic: Warm air hose  (Read 2841 times)
Offline logeyboy
Warm air hose
« on: 16 March 2010, 15:55 »
Afternoon,
It looks like I need a new warm air hose for my '89, 8V, Digi.
Can you still buy these new?
If not, I'm sure any old hose should do, but I'd need to know the diameter?
Offline peaky83
Re: Warm air hose
« Reply #1 on: 16 March 2010, 15:59 »
Try GSF failing that try VW they should both be able to give you a diameter/dimensions if not the part you need. Failing that try a scrappy...
It needs to be a heat resistant hose as it comes from the exhaust manifold and passes over it, so in answer to your question no you can't use just any hose.
Offline Richie
Re: Warm air hose
« Reply #2 on: 17 March 2010, 21:46 »
I ordered this a couple of years ago from VAG.
P/N 027 129 627E   £26.35 + vat  ouch!!!!!!!!!!!!!!!!
Different material, came too long and didn't like being bent around the corner to the manifold.
Offline johnson6672
Re: Warm air hose
« Reply #3 on: 17 March 2010, 22:00 »
Need to make sure its the fabric type not metal, at least i know this is the case with with carb models.
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline peaky83
Re: Warm air hose
« Reply #4 on: 17 March 2010, 22:28 »
Yep that's right it's like thick paper to the touch with a metal wire coiling through. Not sure how effective the warm air feed is...?
Offline logeyboy
Re: Warm air hose
« Reply #5 on: 18 March 2010, 07:42 »
Offline johnson6672
Re: Warm air hose
« Reply #6 on: 18 March 2010, 19:11 »
defo looks and sounds right, i would go and check for you but i am laying in a hospital bed
Offline yamz89
Re: Warm air hose
« Reply #7 on: 18 March 2010, 20:46 »
I'd seen this...
http://www.veedubmachine.co.uk/index.php?main_page=product_info&cPath=3_20_77&products_id=611
but not sure on diameters
This is the stuff you need. Volkswagen still sell this but for cheap as its from the classic aircooled beetle heating system. VW used to use the same size ducting house on all of there cars. Why waste what they already had??
71' Beetle in Marina Blue
05' Octavia vRS
10' Golf GTi
Offline dadrathers
Re: Warm air hose
« Reply #8 on: 18 March 2010, 21:28 »
Richie has it spot on with part number and 'features' of the hose supplied - mine is perfoming fine though - should do for price!
