Author Topic: ANTI ROLL BAR DROP LINKS Adjustable from 119mm to 155mm  (Read 4424 times)
Offline redevo1
  • golt gti 1.8t AGU
Would these solve the rubbing on the drive shaft as it says in the advert used with the standard front ARB? Don't really want a uprated front ARB but getting the dreaded rub on bumps??
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220558263315&ssPageName=STRK:MEWAX:IT
Cheers for any help  :smiley:
God I've got a golf I'm getting old!Full Recaro leather with arse waming seats, the reason for buying a Golf!Spec: R tech remap:Eibach Fr+Rr ARB:Powerflex ARB bushes:Forge BOF DV:Silicone TIP:Induction kit:Jamex suspension:312mm big brake setup: EBC pads F+R:Vr6/g60 clutch:5mm-fr+15mm-rr spacers: Anni front & rear Valances & Anni rear roof spoiler: Silicone hose boost/Breather kit.
Offline ashw831
Re: ANTI ROLL BAR DROP LINKS Adjustable from 119mm to 155mm
« Reply #1 on: 16 March 2010, 15:20 »
i would think so.. they look the same to all the other ones i have looked at... good find matey, i was on the look out for some, you found cheaper than i did!! :wink:
Offline redevo1
  • golt gti 1.8t AGU
« Reply #2 on: 17 March 2010, 08:54 »
Thanks Ash. :smiley: Was looking at a front uprated ARB but happy with the handling and been spending a small fortune the last couple off months on the cars so if this will sort the rubbing will save a big cash out lay.
Offline Adam
« Reply #3 on: 17 March 2010, 11:40 »
I have them, they work for me.
Just take the nut out to make it shorter and you wont have any issues.
Down Hill From Here.
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #4 on: 17 March 2010, 11:48 »
i take it then adam these aren't those veemaxx ones  :undecided: i looked at them from the link fair price as i still have an issue with slight noise/rubbing on rh lock just don't want to be fitting a front arb if these were ok i'l bin the veemaxx ones and opt for these
2000 Mkiv GTi 1.8T AGU
Offline ashw831
« Reply #5 on: 17 March 2010, 12:59 »
Make it shorter... i thought you had to make it longer to lift the arb over the drive shaft?   :huh:
Offline Adam
« Reply #6 on: 17 March 2010, 13:42 »
Nope apparently shorter to miss the ARB hoop. Although I don't know why?
I dont know but I bought the FK ones from Venom and thais is the pair I got so I think venom are swindling people. :huh:
