Author Topic: steering/ brakes vibration  (Read 5316 times)
Offline richy
  • neeeeeeeowm
« on: 08 November 2004, 14:14 »
My steering feels a bit light when going at speed i.e. 90mph+ (not that I ever do this on public roads), which it didn't used to.
Also when I break gently from anything over 50mph, I get a bit of virbration through the steering wheel.   Could this be warped brake-discs?
Both of these problems seems to be getting a bit worse recently.  Are they likely to be connected, and what you do reckon the problem could be?
Cheers,
Rich
54-plate Golf 2.0 FSI GT.  Leather interior.
Offline Len
Re: steering/ brakes vibration
« Reply #1 on: 08 November 2004, 14:30 »
Unlikely to be warped discs - u would get that every time ya touched the brakes.
Looking at the age of your car, its probably not track rod ends either.
Too much guesswork.
www.sas.org.uk
www.the-ace.org.uk
Offline hairyarse
« Reply #2 on: 08 November 2004, 17:45 »
Aside from wheel balance, I've been told before that warped discs is a possibility. I've had this on my BMW before - and do at the moment. Replacing the discs had sorted it but keeps coming back. Car was in for a service today and reported this again. Garage tell me could be the hubs or could even be a suspension problem!
Offline richy
  • neeeeeeeowm
« Reply #3 on: 08 November 2004, 17:54 »
Wheels were supposed to be balanced when I got the tyres changed, but will get this checked out at first, before going any further with expensive discs/suspension work!
Any other ideas peeps?  ???
Cheers,
Rich.
VeeDubGTI16v
« Reply #4 on: 08 November 2004, 17:59 »
your cars too new i would have thought for bits to be wearing out, prob wheel balancing like said
Offline richy
  • neeeeeeeowm
« Reply #5 on: 08 November 2004, 18:20 »
Got wheel alignment checked not so long ago, and everything was OK.
Maybe a weight has fallen off since my tyres were changed tho' causing wheel balance to go awry. :P
Offline hairyarse
« Reply #6 on: 08 November 2004, 19:44 »
Yup, the balancing should always be done when having new tyres fitted - I'd be surprised if it wasn't done.
Like you said, you could have knocked a weight off, hit a larg pot hole or something?!!
Offline richy
  • neeeeeeeowm
« Reply #7 on: 08 November 2004, 20:40 »
every pot hole feels big with these low profile tyres and hard suspension!  My alloys are still immaculate tho', so can't have been too bad.  ;D
Offline richy
  • neeeeeeeowm
« Reply #8 on: 18 November 2004, 09:04 »
Took my car to the stealership a few days ago and they discovered unacceptable play in the steering rack, which they can replace under warranty which runs out next month  :D
They also recommended I get new brake discs (not under warranty), but it'll need a service soon, so I'll leave em till then.
Offline richy
  • neeeeeeeowm
« Reply #9 on: 22 November 2004, 08:30 »
In with the stealer today.  Hope it gets sorted alright!  :-\
