Author Topic: Coilovers fitted with RS4 TT Reps  (Read 1998 times)
Offline Dan_GTI
  • GTi addict formally known as yoof
« on: 15 March 2010, 12:41 »
fitted with 5mm spacers, now there still rubbing do i go with 10mm spacers OR hubcentric spacers. Also theres a clinking coming from the passenger side  :undecided:
MK4 H&R 50MM SPRINGS FOR SALE £100 BRAND NEW
Offline Dan_GTI
Re: Coilovers fitted with RS4 TT Reps
« Reply #1 on: 15 March 2010, 13:53 »
can anyone link me up where i can get some 15mm hubcentrics??
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #2 on: 15 March 2010, 13:56 »
had the same problem i ended up fitting 13mm ones have a look here  :wink: http://www.venommotorsport.com/product_details.php?id=2849&manufacturer=FK&category=Wheel
2000 Mkiv GTi 1.8T AGU
Offline Dan_GTI
« Reply #3 on: 15 March 2010, 13:59 »
did you go for the B+ option with the extra shim diddlies?
  • "1.8T AGU"
« Reply #4 on: 15 March 2010, 14:06 »
not for the front i got A+ hubcentric ones (bolt thru) and just got the longer bolts from them to and then got some longer lockers as well so you would need if going say 15mm you need 43-45mm bolts as  your running Rs4 reps then a taper 60degree seat bolt is what you need :wink:
Offline Dan_GTI
« Reply #5 on: 15 March 2010, 16:13 »
cheers  :cool:
will try and find the bolts online, get them sorted and bolted on and ill post some pics  :evil:
found what the rattle was too, the metal wire that sits on the outside of the caliper has gone awol and the pads must be vibrating  :embarassed:
Offline rench
« Reply #6 on: 15 March 2010, 16:45 »
http://cgi.ebay.co.uk/18-AUDI-A4-RS4-STYLE-ALLOY-WHEELS-TYRES_W0QQitemZ290409014932QQcmdZViewItemQQptZUK_CarParts_Acc_Wheels_tyres_Rims_Car_Wheels_ET?hash=item439db9e694
is that what alloys you have? im running the same but dont have no rubbing, ware they rub? ill have to check mine.
Offline Dan_GTI
« Reply #7 on: 15 March 2010, 20:57 »
the tyres only just clear the shocks, the driveshaft on driverside hits the arb thats why you need an uprated one, does the fk arb have the same size outer loops to clear as the eibach?
Offline Steve_PD
« Reply #8 on: 15 March 2010, 21:15 »
there's a GB on ukmivs for a whiteline arb or you could try adjustable droplinks
Offline rench
« Reply #9 on: 15 March 2010, 22:20 »
i take it only hits over bumps? not notiched mine yet anything to listen look out for?
