Author Topic: Horn not working  (Read 4714 times)
Offline Dmonday
Horn not working
« on: 14 March 2010, 22:27 »
ran into another problem, trying to sort everything out for MOT next month but just discovered that my horn isnt working, it's the later model steering wheel with 2 buttons for the horn. Im not sure weather this has worked since i bought the car as i have never used it, anyone got ideas where to start looking?
cheers, Dan
Offline zdebx
Re: Horn not working
« Reply #1 on: 14 March 2010, 23:18 »
Remove the airbag and check the connections behind it.
My Golf mk3 1.8 SE is FOR SALE - Jetex exhaust + Jamex coilies & More...Only £550! More info here > http://www.golfgtiforum.co.uk/index.php?topic=161711.0
Offline Dmonday
« Reply #2 on: 14 March 2010, 23:37 »
ill give it a shot tomorrow night, cheers
Offline VR6-Joe
« Reply #3 on: 14 March 2010, 23:39 »
If you ever need a horn, I have both from my old 16v. I have no idea why I kept them, but they're in the shed.
Check the plugs on the horn, they may have come off, or may need cleaning up
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Dmonday
« Reply #4 on: 14 March 2010, 23:40 »
any idea where the actual horns are located? :grin:
Dan
Offline VR6-Joe
« Reply #5 on: 14 March 2010, 23:46 »
One of them is behind your drivers side lower bumper grill
The other one is further up if I remember correctly
Offline Dmonday
« Reply #6 on: 14 March 2010, 23:49 »
ill go have a quick look now, cheerrrs
EDIT: Okay so i had a look and i can hear the horn making a really faint clicking noise asif it's trying to work, and if i turn the engine on and press it a few times then turn it off i can hear like a hissing noise and then a very faint pop and it stops, asif air is escaping somewhere between the engine and the 1st horn :shocked:
« Last Edit: 15 March 2010, 00:01 by Dmonday »
Offline admc6
« Reply #7 on: 15 March 2010, 08:35 »
I'm sure mines tied into the alarm siren. Where you use the little key to turn it off or on.
Offline Dmonday
« Reply #8 on: 15 March 2010, 19:49 »
im not sure mine is :shocked:
i checked tonight and there is 2 plugs hanging out where my airfilter used to be (replaced with aftermarket) that's about all i can find at fault :huh: havent had chance to check behind the airbag but i can tell the buttons are working correctly as i hear a clicking from the dashboard when i press either one
Dan
