Author Topic: fitting new clutch  (Read 1636 times)
Offline slyp98
fitting new clutch
« on: 14 March 2010, 21:04 »
hi all , havin trouble with my '89 8 valve digifant , clutch slipping in 4th and 5 th   also hard to get into 3rd always im gonna fit a luk clutch and release bearing anyone done this job ?? how hard is it? how much  time is needed thanks
Offline kraM
  • It's not the speed, it's the sudden stops...
Re: fitting new clutch
« Reply #1 on: 14 March 2010, 22:44 »
depends if you ever done a clutch before, if your doing it, and what tools/working enviorment you have.
You should do it in a day on your back in the drive easily, providing you have a good supply of tea and toast...
On a ramp with air tools, less than 2 hrs.
Only difficult-ish bit is summoning the strength of ten tigers when 'twisting' box off, as the O/S driveshaft flange will hit the back of the fly-wheel.
Oh and buy a new green knock on cap for the end of the box, and a 'push-rod' seal for the input shaft, as these often get overlooked (they are tiny) and are the biggest cause of clutch slip in older motors...
kraM
It's not the speed... it's the sudden stops...
Offline slyp98
« Reply #2 on: 15 March 2010, 21:07 »
thanks for the quick reply , where would i find a cap for the back of the box? readily available in motor factors ? and also the input shaft seal ,gsf??
Offline Ben Lessani
« Reply #3 on: 17 March 2010, 13:00 »
I wouldn't use GSF for a seal unless they could provide Elring.
Offline slyp98
« Reply #4 on: 17 March 2010, 18:52 »
so main dealer ? or where ?
