Author Topic: Dodo Juice blue velvet sample pot  (Read 2058 times)
Offline naturn007
« on: 14 March 2010, 09:42 »
Hi all,
I have a 30 ml sample pot of the above product.
Can someone tell me how much coverage to you get from one of these pots.
Offline MDSS MK6
Re: Dodo Juice blue velvet sample pot
« Reply #1 on: 14 March 2010, 11:05 »
Should do at least 4 or 5, less is definately more with waxes :smiley:
Cancelled Order
Mk5 R32 instead.....and change too:)
Offline Dan J
« Reply #2 on: 14 March 2010, 15:06 »
7 to 10 if you apply it properly and as said above less is more, the more you put on the more you have to remove which is waisted product.
dampen your applicator before you use it as this helps, hasnt got to be dripping wet but make sure its not dry as it absorbs the wax.
« Last Edit: 14 March 2010, 15:09 by dubplate Dan »
