Author Topic: Advice: front spot light removal  (Read 1356 times)
Offline simon44
« on: 13 March 2010, 16:51 »
Hi, not going well today! Have removed centre lens between indicator and spot light, have removed two screws, but the light wont come out as the housing is too wide. There is a white tube with screw embedded in there, have tried loosening this which has now snapped. Spot not budging. Any thoughts?!
Cheers,
Simon
Offline VR6-Joe
Re: Advice: front spot light removal
« Reply #1 on: 13 March 2010, 16:55 »
Stick a flat headed screwdriver between the bumper (nearest the number plate) and the fog light, and prise the light out, it will come out at an angle
You say you've undone the screws, well on the other side of the fog light is a metal clip, hence why you have to prise it out
It's easy when you know how to do it.
Oh and the white plastic bit you snapped is the adjuster for the fog light so if you're refitting them you might wanna invest in some new ones lol
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline simon44
« Reply #2 on: 13 March 2010, 17:08 »
Great, many thanks. After moving the spot from left to right and being a bit more positive with it its out now, wasn't easy though! Will see if I can fix the adjuster now.
Simon
Offline VR6-Joe
« Reply #3 on: 13 March 2010, 17:12 »
No problems, glad to help out where I can
