Author Topic: Seem to have a problem  (Read 1093 times)
Offline TJJONESVDUB
  • Give me lip and il tattoo daihatsu to your head!
« on: 12 March 2010, 22:43 »
Ok when I'm in say 2nd gear rolling if I don't touch the accelerator it seems the engine pulls back as if the brakes are being put on slightly. I've recently bought a new genuine MAF so don't think it's that, does anyone else suffer from this.
Offline master_oogwai
Re: Seem to have a problem
« Reply #1 on: 12 March 2010, 22:49 »
I get this too.
The car decreases speed pretty quickly when you release the throttle.
Offline TJJONESVDUB
« Reply #2 on: 12 March 2010, 22:53 »
Yeah it's been a problem for a while but always pushed it to 1 side as I'm not off the gas much  :grin:
« Reply #3 on: 12 March 2010, 23:06 »
I just left it too.
As long as the car increases speed quickly when the throttle is pressed, thats the main thing  :grin:
Offline vwprime
« Reply #4 on: 12 March 2010, 23:54 »
Dos the nose of the turbo sound louder?
Im just thinking if ther qir from the turbo isent going where it should be it might be trying to stall itself.
Or
Could maybe, be you throttal body?
What enging code are have you chaps got?
TRANSFORM, & ROLL OUT!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 12 March 2010, 23:56 »
engine code? Any fault codes?
« Reply #6 on: 13 March 2010, 08:29 »
I have an AGU 1.8T.
The car was serviced by r-tech back in jan this year with a full throttle body clean. Only problem they found was a split pipe, which has now been replaced. I think they cleaned the TB again when i had the ko3s fitted couple of weeks ago too. As for vagcom, I put the car through it three times last week, as I swapped the maf over, no error codes.
I dont notice any sound difference since fitting the ko3s, but the recirc valve seems to be louder since fitting the new maf.
