Author Topic: Remote Central Locking  (Read 902 times)
Offline VR6_Wherry
« on: 12 March 2010, 14:29 »
Help! Sorry if it's a repost, but i did search and couldn't find anything!
Basically whats happened is, i unlocked my VR using the fob, took my old head unit out and pulled up the side strips near the door because there were wires hanging out. Then i decided enough was enough and i should get some food. Closed the door and pressed the button to close the door but nothing happened!
I don't even know where to start as i've never had Remote locking and wouldn't know where to start looking!
Thanks in advanced!
Offline Golf_GT_TDI
  • 2015 (65) Golf GTD, 2016 (66) Golf GTI
Re: Remote Central Locking
« Reply #1 on: 12 March 2010, 14:46 »
alarm system fitted? or just remote closing kit? does c/l still work off the key? sounds like you disturbed some wires/connectors down in the footwell area?
Offline VR6_Wherry
« Reply #2 on: 12 March 2010, 14:58 »
No alarm just Remote Central Locking, yep works fine with the key. i know theres no issue with the fob as i have two and one is mint and deffo works! I just really need to know where the unit is, if any one can point me in that direction??  :sad:
Offline Deano2711
  • 1992 VR6
« Reply #3 on: 12 March 2010, 15:14 »
Central Locking control box is usually located behind the glovebox (or may be the passenger airbag if you have one). I would remove the lower passenger dash trim or lower glovebox if you have that and have a look up there buddy.      Cheers     Deano
Offline VR6_Wherry
« Reply #4 on: 12 March 2010, 15:28 »
ahhh so thats probs why i struggled getting the head unit out until i heard a little snap! Would be behind the airbag then
Cheers Deano!
