Golf mk4
Wazzzer
et50 offset to far off for gti t ?
Topic: et50 offset to far off for gti t ? (Read 1252 times)
aaran
12 March 2010, 12:40 »
any issues running an et 50 alloy wheel on a mk4 gti turbo guys? 16x7 or will these foul the arch lip. think calliper clearance will be fine with them
(stock 282mm brakes)
Rhyso
Global Moderator
Sir Postalot
Re: et50 offset to far off for gti t ?
12 March 2010, 12:45 »
won't foul the arch lip as it will sit about half a mile inside the arch
Smaller number = bigger poke
Bigger number = more tuck
Fire Up The Quattro
Wayne
Sir Postalot
12 March 2010, 13:40 »
You could run spacers, I am guessing they are Scooby rims.
Pat
12 March 2010, 15:06 »
and if they are Subaru rims, the centre bore's not big enough
Wayne
Sir Postalot
12 March 2010, 15:42 »
Quote from: Pat on 12 March 2010, 15:06
Plus the bolts holes need drilling out.
aaran
12 March 2010, 17:51 »
nope.
im from a jap backround and just seen this set of wedsport rims up near me i should be getting tommorow
http://www.golfgtiforum.co.uk/index.php?topic=147429.0
will look good sanded and polished up, not to bothered about the center bore as i can have them machined out if needs be, any reccomendations for a good set of cheap spacers? would 10-15mm do it as im thinking it might foul the calliper, that is assuming the offset relates to the wheel face and not the wheel lip
Rhyso
Global Moderator
Sir Postalot
Reply #6 on:
12 March 2010, 19:16 »
10 -15mm spacers would just about get you a stock ET
You'd need at least 20mm to make it look half decent
Fire Up The Quattro
Golf mk4
Wazzzer
