Author Topic: power steering  (Read 1685 times)
Offline retromk2craig
  • Mk2 GTI And Mk3 GTI
power steering
« on: 11 March 2010, 20:05 »
can some1 tell me where i mount the power steering pump on 8v. cheers
MK2 8V        MK4 4 MOTION
Offline Maltman
Re: power steering
« Reply #1 on: 11 March 2010, 20:26 »
Under the water pump... have a good look at a Mk2 with it fitted and then decide if it is really worth the time and trouble.
The Haynes manual has a few sentences on the topic.
Good on you if you are determined and decide to go ahead..
M.
Re: power steering
« Reply #2 on: 11 March 2010, 21:19 »
is this a real sh!t job, i have the car stripped was going to put it all on with engine and subframe out the car.
MK2 8V        MK4 4 MOTION
Offline Maltman
Re: power steering
« Reply #3 on: 11 March 2010, 23:25 »
,,,,,sorry.......that's different... if you have the car prepared as you say, it should be much more straightforward. Presumably you will have the appropriate rack and hydraulic piping, reservoir, and pump.... additional pulleys to link pump to the crankshaft...etc etc.
Study a car which has pas already fitted and you'll have a reference point.
Good luck
M.
Offline Ben Lessani
Offline Jay
  • balding fat cvnt
Re: power steering
« Reply #5 on: 12 March 2010, 13:23 »
Ben your whole project is one big FAQ  :grin:
The MK2 section should be shutdown and redirected to your project  :laugh:
Offline WYATT
Re: power steering
« Reply #6 on: 13 March 2010, 21:45 »
its much easyer with the ening out but mine was already out when i did it , as there is so many brackets/different length bolts , but its well worth it  :smiley:
Joe
