Author Topic: Systoms of F**ked Trackrod End?  (Read 1120 times)
Offline EuanGtTdi
« on: 11 March 2010, 17:22 »
Hey,
just wondering what the systems of a buggerd trackrod end is?
Euan
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
Re: Systoms of F**ked Trackrod End?
« Reply #1 on: 11 March 2010, 17:26 »
u mean symptoms* grab the rob and try moving it, put the car to full lock one side so u can see the joint and grab the wheel moving it left and right to see any play. or a bar on the driveshaft and under the rod to see any up and down play on the joint...
thans what id do hope that helps  :cool:
Offline EuanGtTdi
« Reply #2 on: 11 March 2010, 17:35 »
cheers mate, just when turning right i get a knocking of two things banging together coming from left hub, slower and more bumper it is the worse the banging noise is, defo not the top mounts!
Thanks
Offline G60GTI16V
« Reply #3 on: 11 March 2010, 17:41 »
ah check ur anti rol bar bolts maybe loose i had this, replaced them no more noise  :grin:
Offline EuanGtTdi
« Reply #4 on: 11 March 2010, 18:22 »
whats ones mate? the one that hold the bar to subframe bit, or the bits that join at the end of the roll bar to the wishbone?
cheers bud
Offline redevo1
  • golt gti 1.8t AGU
« Reply #5 on: 11 March 2010, 18:57 »
Sounds like your CV joint?
God I've got a golf I'm getting old!Full Recaro leather with arse waming seats, the reason for buying a Golf!Spec: R tech remap:Eibach Fr+Rr ARB:Powerflex ARB bushes:Forge BOF DV:Silicone TIP:Induction kit:Jamex suspension:312mm big brake setup: EBC pads F+R:Vr6/g60 clutch:5mm-fr+15mm-rr spacers: Anni front & rear Valances & Anni rear roof spoiler: Silicone hose boost/Breather kit.
Offline G60GTI16V
« Reply #6 on: 12 March 2010, 17:53 »
cheers bud
ye the roll bar link bolts
Offline EuanGtTdi
« Reply #7 on: 12 March 2010, 17:55 »
solved it mate cv joint at the gearbox end is away!!
new one of order  :smiley:
Offline G60GTI16V
« Reply #8 on: 12 March 2010, 18:41 »
ah un lucky bud that other dudes guess was better than mine 1 point for you  :tongue:
