Author Topic: poorly Vr6  (Read 1829 times)
Offline ginga
poorly Vr6
« on: 10 March 2010, 05:43 »
hey need some medical advice the 6 is running pants it splutters got wee bit of back fire and does this all through the rev range. i have tried to clean the maf but hasn't made the slightest difference..any ideas anyone
Offline bmw156
Re: poorly Vr6
« Reply #1 on: 10 March 2010, 07:18 »
checked ya spark plugs?
checked for air leaks?
not sure if it has one, but crank sensor?
Offline VR6-Joe
Re: poorly Vr6
« Reply #2 on: 10 March 2010, 10:52 »
Common problem on the VR is plug leads (my dad went through two sets)
Or coilpack if it's an OBD2
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline ace
Re: poorly Vr6
« Reply #3 on: 10 March 2010, 10:53 »
would start with leads, plugs and coilpack
Offline ginga
Re: poorly Vr6
« Reply #4 on: 10 March 2010, 13:11 »
is the coil pack easy to remove?
Offline ace
Re: poorly Vr6
« Reply #5 on: 10 March 2010, 13:44 »
Offline FlySpeck
Re: poorly Vr6
« Reply #6 on: 10 March 2010, 13:51 »
what year is it mate? Does it have a distributor on the end of the head, or a rubber block where the plug leads come out of?
If its a dizzy (obd1) then the coil is bolted under the wiper panel, can see it wi the bonnet up, only 2 screws hold it on I think, and the other kind (obd2) is a proper 6 way coilpack bolted to the rhs end of the head.
Here is a great write up on that maf (well its the audi S2 one but identical to the obd1 vr6 maf) to test it and see how it should be cleaned, great pics too.
http://s2central.net/ds_G70.html
The hoses are rubbish and do split esp. on the breather side underneath where the oil collects lol
The early vrs have a rubber inlet tube thats good, but the later ones are plastic and they crack sometimes, letting in un-metered air.
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: poorly Vr6
« Reply #7 on: 10 March 2010, 14:06 »
Before doing anything get the codes read....might help point you in the right direction.
Offline FlySpeck
Re: poorly Vr6
« Reply #8 on: 10 March 2010, 15:20 »
+1 - first place to start if you can. Makes life easier knowing where to start looking mate.
Offline ginga
Re: poorly Vr6
« Reply #9 on: 13 March 2010, 06:33 »
just want to ad that the only does it when its warmed up to runnin temp
