Author Topic: is this the right procedure...  (Read 2051 times)
Offline nadlad
  • Building Surveyor MRICS
« on: 09 March 2010, 15:34 »
 new to this...
1) wash
2) megs clay bar
3) wash again/dry
3) BUFF using autoglym ultra deep shine (as my car is black) using a KESTRAL DAS  6 buffer machine and menzerna pads
4)then hand wax using dodo juice
5) then seal using autoglym sealant
what do u think?
<<<Big Build Thread>>>
Offline DubSociety
Re: is this the right procedure...
« Reply #1 on: 09 March 2010, 16:51 »
Sounds good enough. Personally unless your paintwork is in need of rejuvenation, you could skip most of that and just Wash, Rinse, Wash, Dry, Apply a Glaze, and top it off with a nice Wax .... but im guessing you have all that purchased and ready to use? in that case, go for it!! :)
Offline nadlad
« Reply #2 on: 09 March 2010, 17:37 »
i just thought ad try get the swirls out ave refined the procedure to this now
1) wash dry
2) clay wash dry
3) super resin polish using DA on mens polishing pad
4) doda lime juice sh!t using a DA and a mens finishign pad for final polish and bonding
5) use dodo canouba wax for sealant
6) and possiby give it another coat of extr gloss protection
lol!
Offline Dan J
« Reply #3 on: 09 March 2010, 18:27 »
sounds like youve got the idea apart from what way round the wax and sealent go, sealent should be applied before the wax as it your protection and if youve got a good sealent it should give you 6/12 months of protection, wax is for adding gloss and is your final layer of protectent, the wax will give way before your sealent will so waxing after sealent in theory will extend the durabilty of your sealent.
hope this helps.
