Author Topic: gti badge  (Read 2269 times)
Offline mossy1969
gti badge
« on: 09 March 2010, 14:19 »
seems like a silly question this but im in the process of buying a gti ,the only thing is that it has no gti badge on the back tailgate.i have priced up the badge and its only a tenner but you dont get any templates or dimensions for correctly positioning the badge.hopefully someone out there will shed light on this one either with a tape measure .many thanks
Offline FamilyDub
Re: gti badge
« Reply #1 on: 09 March 2010, 15:24 »
Take the opportunity to play about a bit...? Under the centre badge  :nerd:
MKV GTI | Reflex Silver | 5-dr | Anthracite 17" | Manual | Highline MFD | Cruise | Revision 'D' DV | Dirty Pipes |
The GTD is like a blow up doll. The GTI is like a proper woman. Sure the doll might last longer, and the woman might have higher running costs, but which would you rather have?
Offline dan_apps
  • too low for british roads!
Re: gti badge
« Reply #2 on: 09 March 2010, 15:40 »
the badge has lugs on it that when pressed to the lift handle will line it up in the correct position.
Offline mossy1969
Re: gti badge
« Reply #3 on: 09 March 2010, 17:59 »
sorry dont know what you mean has the tailgate got holes in it for the lugs on the back of the badge to clip into  cheers
Offline stealthwolf
Re: gti badge
« Reply #4 on: 09 March 2010, 18:30 »
Is it from a dealer or private? If private, why debadged?
If dealer, get them to stick it on for free.
The GTI badge at the back is glued on - no tabs or anything. Either dan_apps is thinking of the front GTI badge or of the VW badges. There's proper dimension information somewhere. Will have a dig around for you.
Offline stealthwolf
Re: gti badge
« Reply #5 on: 09 March 2010, 18:31 »
Have a look here >clicky<
Offline mossy1969
Re: gti badge
« Reply #6 on: 09 March 2010, 19:33 »
many thanks i knew one of you guys would sort it .................will get some pictures uploaded when i get it   ,,,cheers
Offline dan_apps
Re: gti badge
« Reply #7 on: 09 March 2010, 19:45 »
sorry as Stealthwolf said, was thinking of the OEM badge!
Offline AlanD
  • MK5 2.0T 16v
Re: gti badge
« Reply #8 on: 10 March 2010, 13:25 »
Fooking retard :rolleyes:
