Author Topic: Help needed with my GTI :(  (Read 2444 times)
Offline vwvwvGTI
« on: 09 March 2010, 10:37 »
Having serious problems with my MK4 Golf GTI 2.0i
The car drives great except now if I try to "floor it" when overtaking etc, it seems to loose power and stutters, yet if I accelerate slowly it runs perfect!
the loss of power (engine stuttering) really worries me. also if I rev it it sounds as though there is a hole in the exhaust, but I have had it up on a lift and couldnt see any!?!
I used the VAG-COM cable and soft and my car read back...
Quote
16806 - Main Catalyst: Bank 1 : Efficiency Below Threshold  :cry:
P0422 - 35-00
can anyone tell me what would cause this stuttering? and if there was a hole somewhere in the exhaust system, such as the manifold, would it cause this loss of power affect?
any help or advice would be great !
Thanks in advance!
Offline oliver07
  • golf gti T 200BHP
Re: Help needed with my GTI :(
« Reply #1 on: 09 March 2010, 10:40 »
start your car put your hand over the tail pipe if the car is close to stalling no hole if it ticks over as normal hole as the gasses are escaping
Offline vwvwvGTI
« Reply #2 on: 09 March 2010, 10:42 »
Good Morning Oliver,
Thanks for the info I just tried it and the car stalled, so im guessing its no holes in the pipe?
Any other ideas?  :cry:
Offline oliver07
  • golf gti T 200BHP
« Reply #3 on: 09 March 2010, 11:01 »
vag com
as i would have said
maff
dirty throttle body
coil pack
plugs
Offline TJJONESVDUB
  • Give me lip and il tattoo daihatsu to your head!
« Reply #4 on: 09 March 2010, 11:04 »
i would say MAF & plugs myself
Offline vwvwvGTI
« Reply #5 on: 09 March 2010, 11:18 »
Firt off let me thank you for trying to help! I posted so many times and with no reply  :cry:
second, Could the MAF really cause the loss of power, and by this do you mean the MAF sensor???????
I also wondering could anyone illustrate with pics or diagram, where the following are located? plz?
> dirty throttle body
> coil pack
« Last Edit: 09 March 2010, 11:31 by vwvwvGTI »
Offline oliver07
  • golf gti T 200BHP
« Reply #6 on: 09 March 2010, 11:42 »
mate use the search section or the maintanance section under mk4 the coil pack is the part that fits over the spark plug you will have 4 of these check to see if its fully pushed down or look for any cracks in the unit.
if the maff is dirty it will give poor running as said follow the links and give it a good clean
Offline Rhyso
« Reply #7 on: 09 March 2010, 11:45 »
Pretty sure the 2.0 only has an ignition coil and not seperate coil packs
Offline oliver07
  • golf gti T 200BHP
« Reply #8 on: 09 March 2010, 11:48 »
glad your on to share your knowledge on this.
 I have the gti T had a few running issues so just putting ideas forward.
Offline Rhyso
« Reply #9 on: 09 March 2010, 11:52 »
sadly my knowledge is limited - wrong fuel lol
I'd say you're on the right lines though  :smiley:  Only thing i would say is with regards to the cleaning the MAF you can over clean it and therefore finish it off quicker
