Author Topic: red stripe on grill  (Read 8781 times)
Offline dannydubs
  • mk2 gti,mk3 wagon,mk5gti
red stripe on grill
« on: 08 March 2010, 20:44 »
im running a badgeless grill atm and want to put a the red stripe round it like the orignal grills just wondering if any one done this has got any tips of how to do it.
.....the project.........
Offline Gloves88
Re: red stripe on grill
« Reply #1 on: 08 March 2010, 21:08 »
Few different techniques.....
Best bet is to use the search function on this one but as I'm waiting for something to install I'll share :)
Option 1  - (most common I believe) buy some red stripe tape, ebay has it I think then just run it round the grill.
Option 2 - is get some red paint and masking tape and just tape up either side of the stripe all the way round the grill, then just give it a couple coats of paint.
I did option two, takes a bit longer to do, esp if you want clean finish but I think it gives a much better result over all.
Offline dannydubs
« Reply #2 on: 08 March 2010, 21:12 »
i gave the tape idea a go b4 bt it didnt wana go rd the corners properly
and the painting did you mean spray paint or hand painting also did you rub it down a little first.
Offline twistedblack69
  • Proud mk2 user and abuser
« Reply #3 on: 08 March 2010, 21:31 »
I did option 2 aswell, I masked off the bits around the grill and just used some Hammerite and a paintbrush. Looks alright from a distance (if your picky, Hammerite Brilliant Red is brighter than the original grill red) and I did it on the car with no prep except wiping it down, no undercoat or overcoat. I don't think you need to with Hammerite, but if you were going to do it properly, then it prob would be a good idea to key it. If you're gonna spray it, its not gonna take much more effort to tape some paper down to cover the centre of the grill tbh
Offline Neo Badness
  • Feet are for pedals
« Reply #4 on: 08 March 2010, 23:09 »
Hairdryer, makes tape curve easier. Or rather the heat provided by the hairdyer makes the tape more maleable.
Offline Sam
  • Sam I am
« Reply #5 on: 08 March 2010, 23:14 »
On the grill? My preference is the fridge
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #6 on: 09 March 2010, 00:40 »
There is an easier way of doing this, get a small detail decorators roller from a decorators shop, and use Humbrol enamel paint (Post box red) the type that is used to paint model aircraft. Degrease the grill with meths, and Scothbrite area to be painted, no need to mask! load the roller with paint, and give it one very light coat, leave 24 hours, then give it another... the finish will look like its been sprayed, any excess can be removed with White Spirit and a cotton bud.
Thom
Offline OakeyDoak16v
« Reply #7 on: 09 March 2010, 03:29 »
Or get up early and get a mint grill from a car Booty. I was lucky. Do what Thom says. :smiley:
Offline Maltman
« Reply #8 on: 09 March 2010, 09:13 »
http://cgi.ebay.co.uk/VW-Golf-mk2-8v-16v-GTI-G60-Vinyl-Grille-Grill-stripe_W0QQitemZ270541142522QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3efd8239fa
I bought a pack of the above from the supplier listed....
You get more than you need, but not enough to redo above or below the headlights if you wreck it or break it....
Taking the grill off the car makes for easier access.
Clean the area where the stripe is to go thoroughly with T cut or 1000 wet/dry paper.
Warm the grill plastic with a hairdryer - a little at a time and feed the red stripe vinyl on slowly and carefully. If you don't keep it straight and have to lift it off it will stretch and become thinner and possibly spoil the finish.
The curves above and below the lights take time and patience, but the tape will go on without wrinkles if applied a little at a time and rubbed on to the warm surface.
Result.... BRILLIANT....I wish I knew how to post a pic..
M.
Offline dan_apps
  • too low for british roads!
« Reply #9 on: 09 March 2010, 11:27 »
there is a vinyl tape to be had, im sure its on ebay, proper high quality and same width as the grill slats aswell.
