Author Topic: Is this the right coding...  (Read 1499 times)
Offline danski
« on: 08 March 2010, 20:00 »
...to activate the blutooth?
I found it here, I copied the relevant bit below. I`ve been speaking to my local indie and hes happy to activate the kit so long as I know exactly what needs doing.
http://www.octavia-vrs.com/technical/bluetooth.html
Coding the car using CAN-BUS compatible VAG-COM
CAN Gateway - Controller 19
This controller uses Long Coding, recoding should be carried out using the Long Coding Helper built into VAG-COM. Select Byte 3 and put a tick in Bit 7 to enable Controller 77 Telephone. Write the Long Code back to the car.
Telephone - Controller 77
The controller soft coding should be set to 0000422
The following channels should be adapted with the values listed -
channel 128 - 0
channel 129 - 6
channel 130 - 2
channel 131 - 130
channel 132 - 0
channel 133 - 1
channel 134 - 0
channel 135 - 1234
channel 136 - 9
channel 137 - 1
channel 139 - 0
Thanks also go to Andrey Economov of Russia for his help and especially for the following information -
If you have a car fitted with the Multi Function Steering Wheel it is possible to modify the coding so that you can use the Mute button on the steering wheel to activate the voice dialling function of the installed telephone system.
Using VAG-COM open Controller 16 - Steering and select Coding 07.
You should see a 7 digit softcode which will be in the format 00xxxxx
The 4th digit from the right corresponds to the steering wheel variant. If you have a 4 spoke MFSW without the Cruise Control buttons it should be a 2. Change this to a 3 and that should convert your Mute button to activate the Voice Dialling.
Golf GTD, 2010, 3 Door, Deep Black Pearl, Leather, RCD510, Reversing Camera, 18" Vancouvers, Storage Pack, R LED Rears, More GTECHNIQ protection than I can shake a stick at....
Offline topher
  • Administrator
  • fully functioning
Re: Is this the right coding...
« Reply #1 on: 08 March 2010, 20:13 »
looks fairly straight forward to me - print that guide off for your man and he should have no problems at all as long as he uses genuine kit
Offline danski
« Reply #2 on: 08 March 2010, 20:27 »
Cheers topher  :cool:
I`ll go see him tomorrow - I fitted all the kit yesterday, just need the coding - I have original vw kit fitted.
