Author Topic: 140 mph clocks  (Read 1891 times)
Offline iansabf
140 mph clocks
« on: 08 March 2010, 19:51 »
Not long bought a 16v, just realised it has 140 clocks. Aren't they meant to have 160 clocks? Its a 1995. Also my mfa doesn't work. Are they easy to fix? Where should i start?
Re: 140 mph clocks
« Reply #1 on: 08 March 2010, 19:52 »
Yes 16v had 160 clocks.
Offline Deano2711
  • 1992 VR6
Re: 140 mph clocks
« Reply #2 on: 08 March 2010, 19:56 »
None working MFA will more than likely be either the stalk or the clocks. However sounds like you need some 160mph clocks though Mate.
Offline VR6-Joe
Re: 140 mph clocks
« Reply #3 on: 08 March 2010, 20:07 »
I'm wondering if your clocks have been replaced with non GTI ones (non GTI's didn't have MFA so therefore wouldn't work!)
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline Mikester
  • Civic Type R
Re: 140 mph clocks
« Reply #4 on: 08 March 2010, 20:10 »
Post a pic of the engine, just to check it is a 16v....
Offline iansabf
Re: 140 mph clocks
« Reply #5 on: 08 March 2010, 20:20 »
lol its defo a 16v engine, the big dohc letters on the top give that away. When u push the stalk you can see the clock cursor move between the different settings mph/mpg/temp etc and you get the 1st number faint sometimes. I think they could be 8v clocks. So know one else has a 16v with 140 clocks then? Mayb i should find new clocks then
Offline Deano2711
  • 1992 VR6
Re: 140 mph clocks
« Reply #6 on: 08 March 2010, 20:26 »
I would defo replace the clocks for the proper ones but would also be wandering about the accuracy of the mileage. Could try checking against the records held on the VOSA mot history site etc.
Offline Mikester
  • Civic Type R
Re: 140 mph clocks
« Reply #7 on: 08 March 2010, 20:37 »
When you replace the clocks make sure you get 16v ones, and not VR6 ones. As they are identical but the rev gauge wont work on VR6 ones as its a 6 cylinder rather than 4 on the 16v.
Offline Deano2711
  • 1992 VR6
Re: 140 mph clocks
« Reply #8 on: 08 March 2010, 20:40 »
Offline snifferdog
Re: 140 mph clocks
« Reply #9 on: 08 March 2010, 20:54 »
Nice, wonder what mileage theyre showing?!
