Author Topic: Acceptable play on a K03s?  (Read 2224 times)
Offline wratey
  • 2000 Mk4 GTI 1.8T
« on: 08 March 2010, 14:26 »
What is the acceptable play in the shaft on a K03s? Ive done a search, and people say no play whatsoever, some say a small bit up and down, some say you have to have play for the oil etc.
Ive seen a K03s to replace my K03, and its got 0.5mm play up/down and side to side, and its done 70k. Would this be ok?
Also it doesn't come with an actuator, so does anyone recommend a forge one, or just stay OEM?
Cheers, Wratey
Offline richw911
Re: Acceptable play on a K03s?
« Reply #1 on: 08 March 2010, 19:22 »
Have a read of this:
http://www.golfgtiforum.co.uk/index.php?topic=146717.0
You pays your money you takes your chance.
Im buying new when the time arises  :smiley:
Offline DarkGti
« Reply #2 on: 08 March 2010, 19:32 »
the best advise i can give you buddy is to buy new, you can never trust any of the crap on ebay that's where i got mine from some guy claiming it had come out off a audi TT and only done 5000 miles,
there is a few turbo company's out there so it pays to shop around i found a good price at a place called the turbo centre for a brand new ko3-052(ko3s) with actuator, fitting kit and 2 years warranty for £558.13
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #3 on: 08 March 2010, 19:35 »
In hindsight I should have bought new, but I was one of the lucky ones. (frantically touching some wood as I type)
You want as little play as possible, but don't forget you need a bit of space for the oil on the bearings
Offline Purely VAG
« Reply #4 on: 08 March 2010, 19:48 »
Small side to side play is normal, back and forth is where its a Big no.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 08 March 2010, 20:39 »
as above  :smiley:
Offline master_oogwai
« Reply #6 on: 08 March 2010, 21:01 »
After reading many stories on here and other forums, I bought a brand new ko3s. It is expensive, but its always better to be safe than sorry.
I was actually quite relieved I changed mine when I did, as when I saw the ko3 that came out of the car, I was shocked. It had cracks all over the place  :shocked:
Offline coolio
« Reply #7 on: 09 March 2010, 02:43 »
cracks is common on k03/k03s turbo's ,as long its not losing any boost or smoking then is fine !  ur new k03s might have cracks inside now u never knows .....
« Reply #8 on: 09 March 2010, 06:12 »
Really?  :shocked:
I cannot imagine it would last much longer though. I will post up some pics later of the ko3.
