Author Topic: ebay discs  (Read 1868 times)
Offline bobreece
Offline Purely VAG
Re: ebay discs
« Reply #1 on: 08 March 2010, 14:15 »
You do know you can't just fit bigger discs without taking the caliper into consideration, im guessing your 2 choices is part of a brake decision and not an idiots mistake of thinking you can fit bigger discs and away you go to any caliper.
And them discs are perfectly fine. Read the MK4 brake guide on brakes.
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline bobreece
Re: ebay discs
« Reply #2 on: 08 March 2010, 14:31 »
yeah i aint that dft upgrading to 4pots got carriers and evything just need hoses and disks dont suppose you could piont me in the right direction for the right hoses for porsche calipers on a golf
Offline Purely VAG
Re: ebay discs
« Reply #3 on: 08 March 2010, 19:14 »
Which porsche calipers mate?
I'd use larger discs tbh
Offline bobreece
Re: ebay discs
« Reply #4 on: 08 March 2010, 20:25 »
996 352 421 thats the part number biggest i can use is 325mm
Offline Purely VAG
Re: ebay discs
« Reply #5 on: 08 March 2010, 20:28 »
Ah yeah ok.
You can use 325mm with spacers on the carrier.
Problem is you need a 325mm disc with 5 x 100 PCD.
Only option with that is Custom bells/Discs i think.
Cupra R discs maybe an option at 323mm, less spacing on carrier.
Daveb does the lines for porsche calipers, he's your man for brakes ! He's on UK-MKIVS, dunno about here.
For hassles sake you could use 312mm Discs and some good compound pads - Ferodo ds2500's, EBC yellows. Disc size doesn't mean a massive thing.
« Last Edit: 08 March 2010, 20:30 by JordyGTI »
Offline bobreece
Re: ebay discs
« Reply #6 on: 08 March 2010, 20:46 »
got pads with the calipers not sure if there any good they same brembo on back so hoping they are?
carnt fit cupra r as they are to wide will these fit golf as they are 6quid cheaper than vw ones
http://www.vwspares.co.uk/product_info.php?products_id=356
« Last Edit: 08 March 2010, 20:49 by bobreece »
Offline Purely VAG
Re: ebay discs
« Reply #7 on: 08 March 2010, 21:35 »
I'd fit 312's then mate, i looked into this before i got my new brakes, I'm using 325's but im using bells/discs:
Offline bobreece
Re: ebay discs
« Reply #8 on: 08 March 2010, 22:46 »
what you mean bells/disks? does have the extra 13mm make a difference?
Offline Purely VAG
Re: ebay discs
« Reply #9 on: 09 March 2010, 14:47 »
As per picture above, notice the disc is bolted to the bell(black)
And regarding disc size difference:
http://www.golfgtiforum.co.uk/index.php?topic=87778.0
