Author Topic: GTI MK4 CD player  (Read 3801 times)
Offline Rhyso
Re: GTI MK4 CD player
« Reply #10 on: 08 March 2010, 14:20 »
did you get the boot changer or the in-dash changer?
if its the former its a dealer only part and will set you back about £40 - then you got to run it from the front to the back..........
Offline Dannyboy90
« Reply #13 on: 08 March 2010, 18:59 »
I got the cable on order now.... I don't know how im going to run it from the head unit to boot though :S Sugestions? :)
Offline Rhyso
« Reply #14 on: 08 March 2010, 19:58 »
run from the headunit down the passenger side - its the only way it will go as the lead isn't long enough to go the other way
glove box out
remove the door sill trim
remove the lower b-pillar trim
remove the trim by the rear seat
remove the trim inside the cubby hole in the boot
You got the bracket to mount the changer in the cubby hole?  think thats about £20 or so
Offline vwjake
« Reply #15 on: 08 March 2010, 20:02 »
i ran mine down the side of the car passanger side under the plastic trim had to take the glovebox out to run it behind wasnt too bad a job plenty of room under plastic trim also ran rca cables for my sub at the same time  :smiley:
did it just like Rhyso says :smiley:
Offline Dannyboy90
« Reply #16 on: 08 March 2010, 20:59 »
Ahhhh, cheers guys, looks like i got the right cable.... I dont think i got the bracket.. Ill have to check!
