Author Topic: Which oil pressure switch do i need?  (Read 1907 times)
Offline julie
« on: 07 March 2010, 18:05 »
Hi i have got a leak from my oil pressure switch but have heard there are two diffrent ones 1.3 bar and 1.8 bar so not sure which one i need to get? it has white bit on it and yellow wire?
also where can i get one from asap?
thanks
Offline julie
Re: Which oil pressure switch do i need?
« Reply #1 on: 07 March 2010, 18:33 »
the car is a h reg 1.8 16v gti golf
Offline jezza16v
« Reply #2 on: 07 March 2010, 18:43 »
Is that the one on the back, gearbox end of the cylinder head that's leaking?
Offline julie
« Reply #3 on: 07 March 2010, 18:49 »
No its on top of the oil filter housing, the front one with the white top and yellow wire wire going to it!
Offline jezza16v
« Reply #4 on: 07 March 2010, 19:43 »
That's the 1.8 bar switch according to the Haynes manual. A VW dealer is your best bet, they can usually get them within a couple of days. You can get them from GSF or Eurocarparts but I've heard they don't last so long.
« Reply #5 on: 09 March 2010, 23:41 »
056 919 081 - oil temp sensor, 1.8bar white - 9.84+VAT
Offline Steve_B
« Reply #6 on: 10 March 2010, 12:23 »
Are you sure it's the switch, could just be a missing washer?
