Author Topic: windscreen seal  (Read 1132 times)
Offline blighty
windscreen seal
« on: 07 March 2010, 16:51 »
Going to be replacing my windscreen soon and want to put a new seal in to make it easier as my current one is a bit old looking so was wandering where the best place to buy a new one from is? heard varied views about seals from gsf about how certain ones from them dont fit as great as they should, obviously I want one that is going to fit well and not leak etc.
Offline Thom89
  • Looking for an "Icebreaker"
Re: windscreen seal
« Reply #1 on: 07 March 2010, 21:29 »
Im pretty sure that where ever you get a seal from, as long as its new, it'll bee ok, generally, they go out of shape while in storage, and for this reason, can sometimes be a bit of a pig to bed in, OE seals are probably still available from VW, lubricate the new seal with french chalk before fitting...
Thom
Offline blighty
Re: windscreen seal
« Reply #2 on: 07 March 2010, 21:35 »
ideal cheers. I will check the price from vw :) where can I get french chalk from? I presume it helps to get the seal in better?
Offline Thom89
Re: windscreen seal
« Reply #3 on: 07 March 2010, 22:43 »
French chalk/soapstone/unscented talcum powder, all the same thing really, can be bought from Boots, or Cycle shops, and can usually be found in cycle puncture repair kits, in stick form, basically, it stops the rubber sticking to itself. On a windscreen rubber it will allow the screen to seat properly, and reduce the likelihood of the rubber tearing, while pulling the string out....
But thinking about it, if you get a new rubber, it'll probably already be coated anyway, so clean it off after fitting, and not befors...
Thom
Offline blighty
Re: windscreen seal
« Reply #4 on: 07 March 2010, 22:51 »
ahh ideal. I will remember that :D nice one. cheers :D
