Author Topic: Its been a productive morning  (Read 1552 times)
kells
Re: Its been a productive morning
« Reply #10 on: 06 March 2010, 16:06 »
mate my adapeters that are on now are just like yours exactly, and 30mm.. bolts came with them to bolt to car then u use standard wheel bolts, just same looking as yours they are aluminium as its needed for the light weight, but the one im having issues with is the bolt holding it on, its made of cheese needs drilling out i think?
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #11 on: 06 March 2010, 16:32 »
I see, ye the bolts are quite soft, have you tried braying a 21/32" socket bit over the bolt, thats just under 17mm so might just go on.
If not you will need a centre drill, an 8mm drill, a 12mm drill and an M14 x 1.5 Tap
Use the centre drill to get the centre point of the bolt, needs to be as central as possible!!! Then use the 8mm drill to depth,  then the 12mm drill, you need to get these as concentric to the bolt as possible!!!! (Any bigger than a 12mm an you will damage the internal thread of the hub)
You should now be able to twist the bolt out, the bolt head might shear when you try this, if so, just scrape all the remains of the bolt out of the hole, blow it out and run down it with the M14 tap.
Or just come up to my work at Wortley next Sunday an we'll get it sorted.
kells
« Reply #12 on: 06 March 2010, 17:22 »
dude PM me your moile number ill come to your workshop next sunday, that would be very good  :cool:
Offline benvictors
« Reply #13 on: 06 March 2010, 17:29 »
^^ PM'd
