Author Topic: Noisy Heater  (Read 772 times)
Offline VWstevo
  • I feel The Need or Speed
Noisy Heater
« on: 05 March 2010, 23:00 »
Hi just started with a noisy heater when i turn the blower on 1 or 2 i can hear a rattling coming from the heater. I have looked under the passenger side dash were the heater/fan is located and i can hear a clicking.rattle noise coming from it. Could it be a leaf that as dropped down into the fan motor making the noise or could it be sumat else. Thanks. :shocked:
« Last Edit: 05 March 2010, 23:21 by VWstevo »
Re: Noisy Heater
« Reply #1 on: 05 March 2010, 23:19 »
Pop off the scuttle panel and remove the pollen filter, you will see the fan then.
Offline boneybradley
  • Back in a Mk3...
Re: Noisy Heater
« Reply #2 on: 05 March 2010, 23:24 »
or remove the lower glovebox/shelf and remove the fan by turning it in its housing (I recon it's come loose..it won't be the first I've come across)
Offline VWstevo
Re: Noisy Heater
« Reply #3 on: 05 March 2010, 23:29 »
ok cheers guys. :smiley:
