Author Topic: Problem with Revo remap. ( Random power loss )  (Read 16550 times)
Offline Snoopy
  • Moderator
  • Geoff.
Re: Problem with Revo remap. ( Random power loss )
« Reply #30 on: 07 March 2010, 09:56 »
... ahh what the hell, its not my car :laugh: :laugh:
:grin:... although im staying shtum on that front. Last week when I told you everything is finally going ok with the car i have to drive home on a flat!!  :sad:
I did think you were mental driving home like you did but now i understand...
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline jdjd
« Reply #31 on: 07 March 2010, 16:11 »
Yeah about 70mph it cuts out, Taking it back 9am 2moro, So will let u know what problem is hopefully they find something :rolleyes:
Offline simonpolly
« Reply #32 on: 07 March 2010, 17:21 »
Mine has done something similar at about 70mph in 4th gear i went to accelerate and it just juddered as if i was in too high a gear untill i dipped the clutch and tried again,it is very intermittent and i never get a fault light come up,the dealer could not find anything wrong. Will be interesting to see what your dealer says.
Golfgti build quality is average at best.
Offline mac7
« Reply #33 on: 07 March 2010, 17:50 »
People like you keep me in business :grin: To be honest you'll probably never have any problems while you own the car. They are tough old motors. It's 5-6 years down the line the abuse shows through. Little turbos + high boost = exhaust housing cracks and leaky seals.
So are you saying that a remapped car is going to be needing a new turbo after 5 or 6 years? Because some of us keep our cars for more than six months and that sounds like a major issue to me.
Golf R
Offline topher
  • Administrator
  • fully functioning
« Reply #34 on: 07 March 2010, 18:43 »
Not at all, only the ones that aren't treated properly. Regular oil servicing (that means t&d schedule .. if you're on longlife service schedule get it changed) and most importantly warming up and cooling down properly.
i can't imagine vw are putting the wrong valve springs in still - i don't mean to sound patronising but could what some of you are experiencing possibly be clutch slip?
Offline R32UK
« Reply #35 on: 07 March 2010, 19:31 »
Toph, would clutch slip cause the car to judder under heavy acceleration??
Offline topher
  • Administrator
  • fully functioning
« Reply #36 on: 07 March 2010, 19:39 »
no but a knackered flywheel might, but then so might a duff spark plug.. you chaps need to start adding vagcom to your options list :tongue:
Offline R32UK
« Reply #37 on: 07 March 2010, 19:41 »
I think you could be right. Went upto wolves today and under full throttle, at say 80 the wheel just seems to judder like one of the wheels has an issue :undecided:
but the dealer told me the 2 fronts were changed for 2 new wheels after last incident :undecided:
Offline topher
  • Administrator
  • fully functioning
« Reply #38 on: 07 March 2010, 19:45 »
if there was any kind of problem in that area it'd normally present itself under full load, so mostly noticeable in 5th or 6th when coming on full boost, so maybe around 3250/3500? when gunning it.
Offline R32UK
« Reply #39 on: 07 March 2010, 19:51 »
cheers toph. think i am going to have to test this theory. I have had it a couple of times before but not payed much attention to it... welll mainly because
1. leeds vw are ghey
2. Huddersfield where i take mine is far away - ish
3. How often do u really need to floor it at 80-90?
4. Its not my car so hopefully the problem will go away if i ignore it :laugh:
Will investigate further.. maybe without the map on
