Author Topic: Does the Gti 8v mk3 have heated door mirrors?????  (Read 865 times)
Offline VWstevo
  • I feel The Need or Speed
« on: 05 March 2010, 20:52 »
I've read that the Gti 8v mk3 has heated door mirrors, can any1 tell me is this correct or not and if so how can you tell. Thanks.
Offline boneybradley
  • Back in a Mk3...
Re: Does the Gti 8v mk3 have heated door mirrors?????
« Reply #1 on: 05 March 2010, 20:54 »
yes...and they work when you use the heated rear screen
Offline VWstevo
« Reply #2 on: 05 March 2010, 20:56 »
Ha thanks mate, that will explain why mine don't work then because my back window heater does'nt work, wot could the problem be with that then any ideas buddy.
  • Back in a Mk3...
« Reply #3 on: 05 March 2010, 21:03 »
fuse, switch, broken wire.....I would start at the fuse then check the switch
Offline VWstevo
« Reply #4 on: 05 March 2010, 21:17 »
ok Brad thanks matey
