Author Topic: rear windscream wiper help.  (Read 901 times)
Offline iamwills
« on: 05 March 2010, 17:57 »
rear wiper moter does not work but water pump does.   the plug that plugs the moter in behind boot cover has number 1,2,3 on it if i run a wire betwen 1 . and 3 it comes on but continuously ,     wot could this be /
Re: rear windscream wiper help.
« Reply #1 on: 05 March 2010, 21:06 »
Column switch burnt out.
Offline iamwills
« Reply #2 on: 05 March 2010, 22:35 »
ware abouts is the switch mate
« Reply #3 on: 05 March 2010, 23:18 »
On the column
Offline iamwills
« Reply #4 on: 06 March 2010, 09:48 »
ok sound mate nice one
« Reply #5 on: 06 March 2010, 10:43 »
not so sure its the switch, the wiper motor and rear wiper get a feed friom the same wires on the column. could be the wiring to the rear wiper motor or the relay. the relay you want is #72 on the fusebox, there is a linky in the mk3 how2 section which shows you where it is.
check the wiring in the rubber boot between the tailgate and car body, good place for splits.
