Golf mk3
hardmonkeys
Loose handbrake lever?
Topic: Loose handbrake lever? (Read 2352 times)
buzzkip
GTI forum regular
05 March 2010, 08:12 »
Hi all,
I've got up this morning and my handbrake lever is loose. When I release the loose hand brake, the handbrake itself is still on so my car can't move.
Obviously because of the cold, but how can I resole this fast?
Thank you
Changed username from "iAMarshall".
VR6-Joe
Re: Loose handbrake lever?
05 March 2010, 08:50 »
You mean the rear brakes are stuck on?
Either try pulling away and give it more revs than normal, or take the rear wheels off and give the brakes a tap with a hammer
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
buzzkip
GTI forum regular
05 March 2010, 10:25 »
I left the engine running for a bit and then the cable went tight again after about 10 minutes
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
05 March 2010, 11:06 »
sounds like the cables are freezing up! if it does it again, look at your rear calipers. if you see the cable is still tight when handbrake released, you know its the cable(s) if the cables all floppy and handbrake mech on caliper is still tight, its the callipers!
if the boot on the end of the cable splits, moisture can get into the cable. then when it gets frosty your handbrake sticks on
buzzkip
GTI forum regular
05 March 2010, 11:35 »
Thanks jonny!
I'll do some checks
Golf mk3
hardmonkeys
