Author Topic: Recaro loom fitting?  (Read 1723 times)
Offline HuwMk2
« on: 04 March 2010, 20:59 »
Hi. Got my Recaros for the mk2, they're in great shape, just a little dirty. Paid £300 for them - bargain!!! Anyway, How do I go about wiring them in? I have the loom with the connectors intact. Where exactly do the two ends go on the back of the fuse box? Cheers.
Offline SimonG
Re: Recaro loom fitting?
« Reply #1 on: 04 March 2010, 21:05 »
You have the loom that can reach the fusebox?  I had to make my own up, easier if you have CE1 electrics as there's loads of spare +ve terminals if making your own. Is your car CE1 or CE2?
  Mk3 Anniversary GTI 16V, Mk2 GTI
Offline HuwMk2
« Reply #2 on: 04 March 2010, 21:08 »
I presume it goes to the fusebox. Its the genuine loom from the car the seats came from!? The seats are from a 1989 car, mine is a 1992 run out.
Offline SimonG
« Reply #3 on: 04 March 2010, 21:19 »
I've never seen a seat loom before so can't comment much.  Is there any chance of finding out if the car the seats came from was CE1 or CE2.  Yours being a 1992 will have the later CE2. Got any pics of the loom and connector in question that you can post up?
Offline HuwMk2
« Reply #4 on: 04 March 2010, 21:41 »
Offline SimonG
« Reply #5 on: 04 March 2010, 21:53 »
Is that all it is? You must be able to find a spare +ve feed on the back of your fusebox for that one connector. You'll have to drop it down and have a look, i'm thinking position Y, bottom left of the single pins as you look at the fusebox with the relays and fuses facing you. Earthing is simple, there is a block underneath the dash above the fusebox, loads of brown wires going to that.  The fuse holder will clip on top of the fusebox as well.
**Edit** Position Y1, just checked the Fusebox sticky by rubjonny.
« Last Edit: 04 March 2010, 22:00 by SimonG »
