Author Topic: ignition probs  (Read 1254 times)
Offline valintino46
ignition probs
« on: 04 March 2010, 11:00 »
just fitted new barrel all fine untill it fires up, it starts thens dies out, are the barrels chip coded or something? on first or second stage turn before ignition, on the dash display it said ' IN 02 ', cnt emember if it ever done that before.
Re: ignition probs
« Reply #1 on: 04 March 2010, 11:03 »
In02 is service due, 1995 on car had coded keys.
Offline valintino46
Re: ignition probs
« Reply #2 on: 04 March 2010, 11:26 »
is it the keys that are coded or the barrel?
Re: ignition probs
« Reply #3 on: 04 March 2010, 11:30 »
Keys are coded to the ecu
Offline sk8boy73
Re: ignition probs
« Reply #4 on: 04 March 2010, 11:39 »
have you fitted the brown thing that goes round the barrel(not sure what its called)!
this reads the chip in the key.
Re: ignition probs
« Reply #5 on: 04 March 2010, 11:40 »
Transponder ring.
Offline sk8boy73
Re: ignition probs
« Reply #6 on: 04 March 2010, 11:49 »
thats it!
Re: ignition probs
« Reply #7 on: 04 March 2010, 12:38 »
keys are coded to the transponder box under the dash, the ecu is then coded to the box.  open your old key and you'll see the small chip, swap this into the new key. if the new key doesnt have a space for it, you'll have to buy a blank transponder type key and get a locksmith to cut it to match the ign lock you just fitted. Local locksmith/shoe repair type place can do it, mine did me one in 2 minutes for a couple o quid.
Key like this:
http://cgi.ebay.co.uk/NEW-UNCUT-KEY-PLUS-TRANSPONDER-FOR-GOLF-PASSAT-POLO-ETC_W0QQitemZ320495943090
in the short term, pop your old key inside the transponder ring and hold it there with tape, stuff up under the dash, job done.
« Last Edit: 04 March 2010, 12:44 by rubjonny »
Offline kr1s77
Re: ignition probs
« Reply #8 on: 04 March 2010, 23:29 »
my local locksmith cut and coded a key for mine for £15
ASV 1.9 TDI 110
