Author Topic: Hose id and part no anyone????  (Read 1176 times)
Offline Lisamk3
« on: 02 March 2010, 13:22 »
Hey all,
Another leaky hose.........Can anyone tell me what this hose is/does and does anyone know the part number? It's split in at least two places and got a bit of oil...well quite a lot actually....leaking from it.
If you look on boneybradleys "common faults and fixes" thread the engine bay pic shows the hose i'm on about clearly. It's got the blue tie thingy round it, coming down from the crankcase black box thingy.
Sorry about the lack of technical terms.......still learning!
Cheers guys. :smiley:
New Stereo - U gotta love it!
Offline FOREST GREEN
Re: Hose id and part no anyone????
« Reply #1 on: 02 March 2010, 13:43 »
Sorry, don't know what the part is, but this pic may help others give you the answer. Hope it helps  :wink:
Offline axewielder
  • 95 dragon 8v
« Reply #2 on: 02 March 2010, 14:27 »
alright man, the hose your on about is a breather hose+ leaks can cause bad running, get a replacement from vw/ scrappy + while your at replacing it clean them all out to maker sure there are no blockages.
Offline Reasty
  • Alpine white valver.
« Reply #3 on: 02 March 2010, 14:41 »
Its the oil breather pipe,have just replaced mine you get the rubber bit at the top and also the hard plastic pipe that goes into the block,the part number is written on the back of the hard plastic piece,it was about 30 odd quid from vw,and mind as you take the old one off as mine was gunked up beyond belief where my car has been running cold.
Offline Lisamk3
« Reply #4 on: 02 March 2010, 15:19 »
Ok cheers guys, much appreciated. :smiley:
Thought the shoddy runnung was down to the throttle body needing a good clean, that's what I was lookin at when I discovered the splits on the breather hose.
Am I still ok to drive the car until I get the new one or is it best not to?
Offline axewielder
  • 95 dragon 8v
« Reply #5 on: 02 March 2010, 16:13 »
fine to drive it, just might make a bit of mess with oily gunk+ will run abit rough
Offline Lisamk3
« Reply #6 on: 02 March 2010, 17:05 »
Nowt new there then :grin: Thanks again :kiss:
Offline Lisamk3
« Reply #7 on: 03 March 2010, 16:56 »
Ordered new one this morn from vw....a bargain at £15!
Ta 4 all the help, just hope I manage to fit it properly now :smiley:
Offline javalin
« Reply #8 on: 03 March 2010, 19:59 »
couldn't be easier.  If it takes 5 min i'd be surprised.
james
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
