Author Topic: Mk3 golf issues... drive shaft ?  (Read 7989 times)
Offline DeathStar
« on: 01 March 2010, 22:42 »
Now sold that golf gti of mine to a mates a month ago.
hes called me up. apparently loads of smoke coming out the back of it :(
So i turn up at his and smell the oil very gearboxy :( so anyway. drive it up the road and the near side drive shaft seems to be clunking badly and its ejected the oil out of the gearbox. took it up the road and soon as you pull away and move the steering clunk clunk clunk.
Now. the cars gearbox was popping out of reverse but it was o.k if you held it in gear, all forward gears where just fine.  told him this when i sold it to him and that i just lived with it.
So what you think. gearbox or shall i try changing the drive shaft ?
Anyone done a drive shaft swap on one? hard job or not? whats the best way to tell if the drive shafts f**ked?
If not then its gotta be gearbox? anyone done a gearbox swap on one ?
James
Offline VR6-Joe
Re: Mk3 golf issues... drive shaft ?
« Reply #1 on: 01 March 2010, 22:51 »
Sounds like a f**ked cv joint. Are you sure it's gearbox oil and not the grease from the cv joint/driveshaft leaking out of a split cv boot?
I go through cv joints like there's no tomorrow (my car is lowered 120mm so it's my own fault), my inner cv joint went once and I ended up with grease all over my engine bay, not nice :(
Not too difficult to change a driveshaft though. 8 bolts on the gearbox end and a large nut in the centre of the hub, although you have to undo the bottom two suspension bolts and pull the hub towards you to get the shaft out of the hub iirc
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline DeathStar
« Reply #2 on: 01 March 2010, 22:54 »
well when its stopped there wasnt much oil on the ground but it smelt greasy/gearboxy oil smell.
seems to be the innit cv thats coming out of the gearbox.
Offline VR6-Joe
« Reply #3 on: 01 March 2010, 23:09 »
Yea I'd start with the cheapest option and get a driveshaft, I normally pick them up for £15-£20 from a scrappy. Get that fitted and see what happens :)
Offline DeathStar
« Reply #4 on: 01 March 2010, 23:12 »
will do.
oh and btw nice looking motor
Offline VR6-Joe
« Reply #5 on: 01 March 2010, 23:19 »
Good luck :) and thanks! :cool:
Offline DeathStar
« Reply #6 on: 02 March 2010, 09:57 »
if i remove the drift shaft. will it piss the oil out from the gearbox?
Offline VR6-Joe
« Reply #7 on: 02 March 2010, 09:59 »
Nope :smiley:
« Reply #8 on: 02 March 2010, 10:55 »
sounds liek shaft has punched a hole in the cv inner seal. cv grease doesnt smell all that much but gearbox oil has a very unique smell, cats wee is one way ive heard it described.  I'd get some new seals just in case, only cheap.
http://www.brokevw.com/020flange.html
Offline Khare
  • The bear that khares
« Reply #9 on: 02 March 2010, 10:58 »
more like atomic cat pi$$  :laugh:
It's very strong smell!
