Author Topic: quick query...?  (Read 1811 times)
Offline ade_aidy_ady
quick query...?
« on: 01 March 2010, 22:20 »
on a fully standard car...... should u be able to hear the turbo whistle.... when u boot it then let off ???
ive been reading that this noise psssssssssssssst could be a duff diverter valve.......? cars 2000 45k miles......
vagcom is throwing up "pressure drop between turbo and throttle valve"..............................?
Offline Adam
Re: quick query...?
« Reply #1 on: 01 March 2010, 22:26 »
Have you also looked for a boost leak?
Down Hill From Here.
Re: quick query...?
« Reply #2 on: 01 March 2010, 22:28 »
checked pretty much all pipes up around the diverter valve etc.... but all seem ok............?
should this pssssstt or woooooosh noise be audible on a fully re-cirulating turbo car when u acclerate and let off.............?
Offline richw911
Re: quick query...?
« Reply #3 on: 01 March 2010, 22:41 »
You will hear it.
17705  :lipsrsealed:
Could be cracked re-circulating valve or a leak - check the pancake pipe joints for signs of oil  :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: quick query...?
« Reply #4 on: 01 March 2010, 22:49 »
I found my old standard valve the other day, looks fine but I can blow straight through it and that was 52k miles when I replaced it :huh:
Re: quick query...?
« Reply #5 on: 01 March 2010, 22:57 »
thanks for replies....
can the pancake pipe be easily viewed from lifting the bonnet or is it a raise and look underneath job.............?
also been getting this code recently.............17608 - "boost presure control valve" (N249) - mechanical malfunction
would this possibly have anything to do with a faulty diverter valve.............?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: quick query...?
« Reply #6 on: 01 March 2010, 23:00 »
pancake pipe is behind your drivers wheel
as for the code, have a search, you'll find loads of topics as it's a sore subject for AUM/AUQ owners  :grin:
Offline jeynesey
  • Non VW but still VAG
Re: quick query...?
« Reply #7 on: 01 March 2010, 23:03 »
AGU ftw. Mine was completely mashed when I replaced it, could put my thumb through a hole in the side!!  :undecided:
