Author Topic: door cards  (Read 825 times)
Offline vicky
door cards
« on: 28 February 2010, 09:21 »
hiya, just a quick question, i need to get my door card off the back door to have a look at my runners for my window, but im unsure how to do it, i cant see any screws to undo and dont just want to pull it off incase it breaks.
thanks vic
Offline VR6-Joe
Re: door cards
« Reply #1 on: 28 February 2010, 10:12 »
Assuming you have a 5dr GTI
1. Unscrew the door pin to remove that
2. The outer part of the grab handle that houses the electric window switch and tweeter will prise off with a flat headed screwdriver but be careful because I've managed to break a tweeter in the past
3. Behind the above grab handle, will be 2 cross headed screws, undo these.
4. The door card will now pull off as it is only clipped on, but make sure you put some effort into it as the clips are quite strong.
5. Disconnect the wiring plug for the speaker
Door card should now be off :)
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline vicky
Re: door cards
« Reply #2 on: 28 February 2010, 13:33 »
cheers joe
Offline christomk3gti
Re: door cards
« Reply #3 on: 28 February 2010, 13:39 »
Had to do mine about a year ago. pretty easy.
good luck :afro:
Black 8v GTI............. Whats a Waffle Valve?
