Author Topic: NCT failure  (Read 822 times)
Offline paulharpur1978
NCT failure
« on: 27 February 2010, 21:03 »
Yup, my car failed the NCT (National Car Test) today. Couple of things were wrong, brake bulb (easily fixed), headlights not properly secured (had them out fixing the rad, not a problem), now the last problem is odd, cracks in the sills, nearside/offside, this is aroun where the car is jacked up, when changing tire. The mechanic recommended some putty, but I don't fancy that. What are the options? Grind down, filler? or spray it with an underbody spray to cover the cracks, or is there a possibility if I don't fix this prob now it will rust and I'll have a major prob. Its a 10yr old MKIV 20V Turbo. Advice?
Offline richw911
Re: NCT failure
« Reply #1 on: 27 February 2010, 21:05 »
Putty??  :shocked:
Any pics?
Re: NCT failure
« Reply #2 on: 01 March 2010, 18:58 »
Yep putty  :laugh: Just looked at  the car today, theres a bit of a hole in one of the cills, about 40mm x 5mm, some filler should sort it out, will take pics when I tackle it on saturday.
