Author Topic: NEED URGENT HELP!!!!  (Read 767 times)
Offline Seth
« on: 27 February 2010, 14:39 »
Went to start the car this morning(mk3 8 valve gti on a '95) and it started only to die immediately I tied two or three times with the same result I then noticed none of the clocks or guages were showing a reeding no lights nothing!, couldnt hear the fuel pump primeing or anything, I then checked the fuse board all ok, I then just by chance moved one of the relays!  and the clocks come back on and the car started and run fine so I set off for a little drive. About 100m down the road the clocks died again but the car was still running so I wiggled the relays again and the clocks came back on for another few hundred meters then went off again so I turned round and got the car back home turned the ignition off and tried to start it again and it died again this time wiggling the relays did nothing :undecided:
So my question is, is it a faulty relay if so which one?(relay number and possition) or is it something else?
Please help me somebody its doin ma head in :cry:
AKA VEEDUBJUNKY
Offline Seth
Re: NEED URGENT HELP!!!!
« Reply #1 on: 27 February 2010, 15:55 »
bump
AKA VEEDUBJUNKY
Offline flexiblefish98
« Reply #2 on: 27 February 2010, 16:05 »
Hey there,
Not sure, but first place to try is ECU 30 relay, top row third from right. Try this link http://www.golfgtiforum.co.uk/index.php?topic=74087.msg592367#msg592367
it tells you what all the fuses/relays do!
ECU is only £12 from VW so might be worth a change.  :smiley:
Offline Seth
« Reply #3 on: 27 February 2010, 16:37 »
thought maybe that was the problem
AKA VEEDUBJUNKY
« Reply #4 on: 27 February 2010, 17:12 »
Let us know how you get on!
