Author Topic: K04 TIP Fit K03s Inlet?  (Read 3148 times)
Offline Purely VAG
« on: 26 February 2010, 22:34 »
As title, Is a K04 TIP the same diameter at turbo inlet as a k03 TIP ?
Reason being i want to use a 3" MAF tube with a k03s hybrid
Thanks,
Jrd,
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline richw911
Re: K04 TIP Fit K03s Inlet?
« Reply #1 on: 26 February 2010, 23:01 »
Dont think so - someone to confirm........
Offline Purely VAG
« Reply #2 on: 27 February 2010, 01:04 »
Anyone  :grin:
Offline MaXXeH
  • Golf MK5 GTI
« Reply #3 on: 27 February 2010, 11:36 »
dont think so as it is larger, you can prob heat it up and slip it over  :smug:
Offline topher
  • Administrator
  • fully functioning
« Reply #4 on: 27 February 2010, 11:39 »
i've seen pictures of one where they tried to do that.. chewed the pipe up. You need a reducer really, but due to the lack of room down there it's a lot easier to use a k03 tip and go up a size at the MAF end.
Offline Purely VAG
« Reply #5 on: 27 February 2010, 11:45 »
Ahhh drat :(
Ok thanks people.
Offline coolio
« Reply #6 on: 27 February 2010, 14:34 »
it won't fit due to the water pipe on the way .... u can use the ko3s tip to fit the 3" maf it will stretch to fit , my mate had it done in his but jbs04 (hybrid k03) just put in boiling hot water a few minute and use bit of fairy liquid ... Job done
Offline Purely VAG
« Reply #7 on: 27 February 2010, 15:18 »
Ive already got a k03s TIP, maybe ill try that.
