Golf mk4
Wazzzer
uprated injector help
Topic: uprated injector help (Read 1562 times)
n.keyte
26 February 2010, 20:52 »
hi all,i have just bought myself a k03s turbo and was advised by the seller to uprate to bigger injectors? so i have been to my local freindly scrappy and had a hunt around,i found an audi v5 so i had those and the 4bar fpr aswell,i also got some from a vvw passat but im not really sure what numbers or id im looking for so any help would be much appriciated.
thanks
Purely VAG
Re: uprated injector help
26 February 2010, 21:01 »
Not required for K03s as per R-tech say.....
✉ Jrd@PurelyVAG.co.uk //
www.PurelyVAG.co.uk
n.keyte
26 February 2010, 21:29 »
ok?but surly a bigger turbo needs more fuel than whats being delivered from the old injectors?
DarkGti
26 February 2010, 21:40 »
you dont need bigger injectors!
Grand Master Patch
26 February 2010, 21:42 »
The AGU injectors can handle a K03s,although testing is still underway to see if any gains can be had from bigger injectors.
Don't worry about it as DarkGti makes almost 240bhp on std AGU injectors
RRP
My car thread
http://uk-mkivs.net/forums/t/201437.aspx
Purely VAG
26 February 2010, 21:55 »
Quote from: n.keyte on 26 February 2010, 21:29
Not true at all. as above. Topic has been covered quite alot and patch is doing some testing to see if any gains by changing injectors, nothing up to now it seems.
www.PurelyVAG.co.uk
n.keyte
Reply #6 on:
26 February 2010, 22:04 »
well
i got 3 full sets all diff sorts so i will leave it for now but take them all with me when i go toR-Tech to have it mapped
Purely VAG
Reply #7 on:
26 February 2010, 22:09 »
lol you can't just use any old injector, you have top and side feed injectors for a start then you have EV6 or EV12 fitment then you have flow rate. Can't just go shopping at scrappy and expect them to be fine and dandy, this aint lego......
www.PurelyVAG.co.uk
Grand Master Patch
Reply #8 on:
26 February 2010, 22:10 »
Do any fit?
RRP
My car thread
n.keyte
Reply #9 on:
26 February 2010, 22:38 »
i know i cant just put any injectors in it thats why i took them from an audi and a passat and asked for help.
im not sure if they fit yet as i got back late tonight
Golf mk4
Wazzzer
