Author Topic: ignition barrel  (Read 2004 times)
Offline valintino46
ignition barrel
« on: 26 February 2010, 16:51 »
if an ignition barrel goes duff can u get a direct replacement so keeping the original key? guessing vw main dealer.
Offline Adam
Re: ignition barrel
« Reply #1 on: 26 February 2010, 17:17 »
Whats the problem with your car?
Down Hill From Here.
Offline Mikester
  • Civic Type R
Re: ignition barrel
« Reply #2 on: 26 February 2010, 17:24 »
Its more than likely the ignition switch thats gone if your having problems starting.
Mine cost something like £120 to replace.
kells
Re: ignition barrel
« Reply #3 on: 26 February 2010, 17:37 »
mine cost £22 from the dealer, fitted myself but the collor can be stuck on meaning cutting it off, new ones of those are about £7
Offline Adam
Re: ignition barrel
« Reply #4 on: 26 February 2010, 17:39 »
How much!!!!
I'v got one sat in my toolbox
Offline Mikester
  • Civic Type R
Re: ignition barrel
« Reply #5 on: 26 February 2010, 17:54 »
The part was only like a tenner, but i paid an auto electrician to fit it, as i really have no idea and there is sheer bolts etc.
Meh.... fixed the problem!
Offline Adam
Re: ignition barrel
« Reply #6 on: 26 February 2010, 17:59 »
Hammer and a chisel works well for shear bolts.
Offline Mikester
  • Civic Type R
Re: ignition barrel
« Reply #7 on: 26 February 2010, 18:01 »
Probably, but i didn't want to break anything. If i ain't confident doing the job and i can afford to pay a professional i trust, then generally i do tbh.
Re: ignition barrel
« Reply #8 on: 26 February 2010, 20:33 »
I replaced the complete inner column on mine, much easier.
Offline valintino46
Re: ignition barrel
« Reply #9 on: 28 February 2010, 11:46 »
the problem was i had to replace the housing that holds the ignition barrel as the race bearing was shot, the whole thing was only £25 from a vw dealer but getting the barrel out was a pain in the arse and ended up snaping the pin which hits the switch when starting, vw dealer wanted £75 for barrel but ive ordered one on ebay for £7 and hope to change the pin only and retain the og key, goes to show somethings from dealer are very well priced but others are stupid prices.
