Author Topic: 2.0 TDI 140bhp/170bhp...what differences?  (Read 4945 times)
Offline A7 UFO
« on: 25 February 2010, 11:37 »
Anyone know what the difference is between the above two engines? (other than the fact one engine is +30bhp  :rolleyes:)
Offline Adam
Re: 2.0 TDI 140bhp/170bhp...what differences?
« Reply #1 on: 25 February 2010, 12:59 »
Turbo and mapping are slightly different.
Down Hill From Here.
Offline spunkymonkey
  • Tepidly moist! That's what that is!
« Reply #2 on: 25 February 2010, 18:32 »
The 170 also has a dpf which arent without there problems. 140 with a remap is the way to go.
Offline Jimp
« Reply #3 on: 25 February 2010, 19:12 »
Maps are different, turbos are the same AFAIK. Both engines remap to about 200bhp. Might be stronger internals or something on the 170 though?
Not low enough mk5
Not on the road enough mk3
Offline JJH
« Reply #4 on: 25 February 2010, 21:00 »
the 170 TDI found in mk5 is PD TDI.
The new 170 in the mk6 (GTD) uses
TDI® with Common Rail and Piezo Injectors The latest generation common rail system has one high-pressure pump and one rail per cylinder bank. The maximum injection pressure is 1,600 bar, 250 bar more than previous common rail systems. When piezo injectors are used for injection, a voltage is applied to ceramic, which changes its crystal structures. The result is a minimal geometric change, which mechanically triggers the opening of the injector needle. The use of piezo injectors makes it possible to reduce the moving mass at the injector needle from 16 to 4 grams in each case. This enables considerably smaller and more precisely metered injection quantities. At the same time, piezo technology allows a higher injector needle speed.
The number of injection processes per combustion cycles can thus be varied almost at will. The 3.0 V6 TDI engine, for example, has up to five injection processes: in addition to the main injection process, double pilot injection takes place at the lower end of the speed range and single pilot injection in the medium speed range. On top of this, single post-injection takes place up to around 2,500 rpm and at maximum part-load. This reduces emissions and ensures a smoother combustion process.
Heres even more info on the difference between PD and common rail.
http://www.automobile.com/vw-to-switch-to-common-rail-diesel-technology-from-pd-tdi.html  :laugh:
I've had both and driven over 80000 in each and can confirm the new 170 is wicked.
« Last Edit: 25 February 2010, 21:01 by JJH »
GTD White 5dr, ACC, Sunroof, winter pack, in transit.......
Offline Agreeable Slick
  • Unit
« Reply #5 on: 25 February 2010, 23:13 »
There are numerous internal differences. Compression Ratios, piston bowl design, injection periods, after treatments etc.
Offline Stu.750
  • MMMMMMM Rust my favourite
« Reply #6 on: 25 February 2010, 23:23 »
Talking of Diseasels
 have VW started selling cars with Add blue systems yet ?
  • Unit
« Reply #7 on: 25 February 2010, 23:25 »
Yes
Also known as a extra tank of piddle.
Offline Stu.750
« Reply #8 on: 25 February 2010, 23:31 »
Pigs piss  :grin:
 just had dealings with it for a while
not sure its the greatest of ideas for cars
  • Unit
« Reply #9 on: 25 February 2010, 23:35 »
it's apparently going to be the way that all engines are going. Urea dosing in the exhaust.
Depending on usage and engine size it could also require refilling after ever other tank of fuel. Happy times.
