Author Topic: brakes overhaul  (Read 4925 times)
jamrock
brakes overhaul
« on: 24 February 2010, 22:31 »
time to replace the front pads and disc and rear shoes and drums on my 1.3
EURO on their website show pads priced at about £10 with a picture of 4 brake pads, under the price it says per axle???
what does that mean? whilst im at it is there anything else i should do regarding the brakes??
and also if its EURO or GSF i should go with??
thanks guys
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
Re: brakes overhaul
« Reply #1 on: 24 February 2010, 22:51 »
Per axle means litterally both sides acorss one axle.. front being a transaxle if you want to americanise it.. but it basically means front 4 pads, rear 4 shoes, or pads if it was a GTI etc. btw discs are almost always sold in singles so you have to quantity 2..
also neither gsf or euro.. try us at www.vwsonline.co.uk though i recommend as it stands phoning instead as i'm yet to be allowed the time and space to complete the website :doh:
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
jamrock
Re: brakes overhaul
« Reply #2 on: 24 February 2010, 23:07 »
sweet beavis!!! :cool:
il def take note of the number and try giving a ring tomorrow. by then hopefully ive got a couple of qutoes emailed through.
i will be sure to mention im off the site!!  :smiley:
can you recomend doing anything else brakes wise??
Re: brakes overhaul
« Reply #3 on: 24 February 2010, 23:27 »
im shattered so brain is in shutdown mode but, bleeding the system, and replacing the rear cylinders as theyre not much money would be a feature while its apart, its not uncommon by anymeans for them to be leaking!
Quote
jamrock
Re: brakes overhaul
« Reply #4 on: 25 February 2010, 23:04 »
now need two front calipers :cry:
my mate is braking a G40 polo, will the front calis from that fit on my 1.3??
Re: brakes overhaul
« Reply #5 on: 26 February 2010, 10:40 »
Yep - with an upgrade to vented discs there as well!
Quote
Re: brakes overhaul
« Reply #6 on: 26 February 2010, 10:57 »
aye they're VWII items exactly same as MK2 GTI 239. make sure you get all the fixings as well, the 1.3 has a shorter bolt/slieve on there which needs swapping whjen fitting venteds. FYI need to biuy both the GTI discs & pads, discs are thicker so the pads are thinner!
