Author Topic: Steering problem help?  (Read 1914 times)
Offline whitey90
« on: 24 February 2010, 00:43 »
Hi everyone,
I'm having a problem with my steering and wondered if anyone else has had the same fault. When steering to the left from the straight ahead position, only about 30 degrees coming up to a roundabout for example, the steering locks up! if you pull harder on the wheel it will go past the problem or just ease off the steering then try again it is fine. I've jacked up the front and the steering is all moving smoothly it only happens whilst driving. Anyone know if the steering racks or steering columns are common on mk2's? this is my 3rd and i've not had this fault before?
Any help is greatly appreciated! ( the car is a 1990 gti 8v by the way ). :smiley:
Offline dub-addict
Re: Steering problem help?
« Reply #1 on: 24 February 2010, 00:50 »
that sounds odd and has never happened to me , but it can only be the steering colum i imagine unless maybe the steering rack itself has become loose (worn rack mounts) and is fighting against it when you try and turn. consider any possiblity
Offline whitey90
« Reply #2 on: 24 February 2010, 00:59 »
Thanks for the reply :smiley:
it is a strange one I couldn't see anything wrong with the rack mounts earlier, I think it might be the uj on the column but I'm not sure :sad:
Offline dub-addict
« Reply #3 on: 24 February 2010, 01:18 »
I had a problem lol a very different one to yours but similar in a way. i did a mk3 dash swap on a mk2 with all thje mk3 vr running gear steering rack to go with it etc , and before i finished halfway through i had to tow the car to my garage . lets just say it wasnt easy to steer , the rack was still loose and i still hadnt fully secured the lower part of the columb  :grin: so the columbs UJ was flexing up and down and steering rack left to right ahh the good ol times ( only last year lol)  :rolleyes:
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #4 on: 24 February 2010, 09:55 »
If it steers fine when jacked up then surely its gotta be the top mounts that are completely shagged, hence when weight is on it hard to turn? Just a guess but it kinda sounds like a bearing has popped outta place or something....
« Reply #5 on: 24 February 2010, 09:55 »
is it power steering? if so, could be belt slippage. replace belt
Offline whitey90
« Reply #6 on: 24 February 2010, 11:20 »
No mate, it's proper steering  :wink:
« Reply #7 on: 24 February 2010, 13:45 »
ah, check your rack boots. could be last bloke who set tracking left em all twisted up, which means they can get caught in the rack threads. otherwise I'd be checking top mounts and column + uj
Offline Bcarm
« Reply #8 on: 02 March 2010, 22:47 »
I know this maybe a bit late but I had this problem once on a non power steering golf, ended up with a new rack.  Hope you get sorted, I had a few near misses as the steering would just jam and needed a good yank to free.
Offline whitey90
« Reply #9 on: 02 March 2010, 22:58 »
Cheers bcarm, I knew someone must have had this before. I'll try a new rack
